Map Point From Generated 3D Model back to Source Image(s)
  • avr.andrei
    • Oct 2023
    Hello all,
    I have a stranger context where I want to use 3d flow.
    I'm generating a 3d model from a set of images which works great. Next, I'd like to select a point (or ideally a surface) on the 3d model, and "project" that point (or surface) on the source image(s) that contributed to it being generated that way.
    It seems possible, since in 3DF Zephyr I can select one of the source images, and it gets overlayed on top of the textured mesh.
    The aim is to do this programmatically using the SDK, but any hint that would point me in the right direction is greatly appreciated. (I'm currently working on deploying the photogrammetry solution in an AWS account)
    Thank you!
