Suggestions to exactly locate hole edges
  • Craig
    • Oct 2022
    • 7
    I have a project where I'd like to find the 3D positions of all the attachment point around an engine. Such as the engine mounts, exhaust ports, bolts, threaded holes, etc. I can get a nice mesh of the engine, but I'm wondering how to locate the center and edges of holes like the exhaust ports?
    I have the full version and will use coded targets for scale, accuracy and to make sure I can tie together projects from the top and bottom of the engine. The engine is not installed so I can see and photograph all sides of it.
    Any suggestions?
    Thanks!
    Craig
    Hi Craig - I'm not sure about locating the center and edges of holes digitally, but you could tape the occluded holes in real life and mark the center with a compass.
    As a general tip you might find that your surface reconstruction improves a lot if you use a fine powder spray - Obviously not possible in some cases, but mattifying surfaces and adding lots of tiny discrete details works wonders for difficult subjects.
    Naturally there are a lot of variables and trial and error will help guide you to the best process.
    • Craig
      • Oct 2022
      • 7
      cam3d, thanks! That's a great idea to use the tape. Simple and effective.
      I've used power and sprays before with shiny objects, and I agree they work well!
      • LarryForehand
        • Jan 2024
        • 7
        What types of powders and sprays have you found effective and how are each applied?
          Larry B - I personally use low scent talcum powder, and for things which are really important and can't be cleaned easily after capture, I used cyclododecane spray :-)
