Ask for help problem Zephyr Lite too much triangles file cannot be edited
  • Segler
    • Oct 2023
    Hello
    I'm new here in the forum and already the first problem!
    I have 3DF Zephyr Lite 7.502.
    I scanned an object (150 images), with the basic settings, with 3DF Zephyr Lite.
    Nothing further edited-EXPORT obj. Ready. The result: Good!
    The problem!!
    The file xxxx.obj has become so large that the object can no longer be edited!
    In the mesh mixer I can't select the object to reduce the number of triangles. Just too sluggish!! Can't do almost anything.
    How and where can I reduce the number of triangles in the 3DF Zephyr Lite?
    Thank you
    Best regards,
    The
    Yachtsman
    you can either use other parameters in the phase of generation or you can use the decimation filters within Zephyr, then export those.
    • Segler
      • Oct 2023
      Hello
      thanks for your help!
      Helped me out.
      Yours sincerely,
      The Sailor
