How to create/export/save a depth map
  • wonderworld
    • Dec 2023
    Hello, I´m trying with the free version 7 of Zephyr to create/ export/save a depth map, but I found no options for this.
    What I did (and this works very good!) is to import a series of photos and create a point cloud as well as a mesh. Then I didn´t find a way to create a depth map.
    Could somebody tell me, how to do this? Thanks in advance!
    Best regards!
  • noramila
    • Aug 2023
    • 8
    Best regards!
    Please confirm that the availability of specific features can depend on the version of Zephyr you are using. If these options are not available in the free version you might need to upgrade from here https://www.3dflow.net/3df-zephyr-ph...etry-software/ to a higher version or use alternative software capable of processing the 3D data into a depth map.
    • wonderworld
      • Dec 2023
      Have a look here: "https://www.3dflow.net/technology/documents/3df-zephyr-tutorials/how-to-export-depthmaps-from-zephyr-to-facebooks-3d-photo/".
      This function should be independent from the apps level (free or higher).
