Very long calculation. Pipeline issue?
  • Sebu
    • Jan 2024
    I notice that the calculation time is very, (very, very) long.
    And yet I have a decent machine configuration.
    So I'm wondering if there isn't a bottleneck somewhere in my config?
    Here https://filebin.net/bogs5suy1vwgnab8 is the log of a current calculation of 580 cameras started 2 days ago.
    Still calculating.
    Why do all the computer components run at a minimum in this final phase?
    CUDA activated.
    Do you have any idea? Or maybe the calculation time is normal.
    Curious to know what the problem is!
    Thanks for your advice,
    Sebu.
  • Sebu
    • Jan 2024
    Well, after 3 days, I finally cancelled the mesh operation on the dense cloud.
    Convenient file sharing. Registration is not required. Large files are supported.
    I'm going to try to divide the mesh into batches of photos.
    GPU is up to date, with CUDA enabled.
    Click image for larger version  Name:	Capture d'écran 2024-01-30 103459.png Views:	0 Size:	15.6 KB ID:	9383
    My config :
    i7-13700K
    RTX 3080 Ti
    RAM 65300 Mo
    Disk SSD
    I think the weak link is the CPU.
    Does anyone have any experience in this area?
    Sebu
      • 1350
      Hi Sebu,
      these processing times are very strange, it doesn't make sense that you have that many hours for coloring. The fact that it takes hours to do something like that makes me thing you're possibly having an I/O issue - where are these images located? Make sure they are on a local fast disk, I don't see anything particularly wrong with your settings or device, so I think this is something in your environment, either I/O or something interfering with zephyr.
      • Sebu
        • Jan 2024
        Thanks for your reply. I've done some tests and it turns out that my SSD drive isn't performing at all.
        So I migrated the photos and the unified and persistent cache to the high-performance NVMe C: drive and, oh miracle, it works like a charm!
