Command line usage
  • kingrichy
    • Jul 2024
    Command line usage
    Hi - is it possible to drive Zephyr from the command line? I need to generated textured models from photosets programmatically without user interaction.
    Cheers!
    for that, you'll need to look into our C++ SDK, FlowEngine: https://www.3dflow.net/flowengine/
    You can use the batching tool (which is a GUI batching tool) in Zephyr, but if you need command line capabilities (or in general, automation capabilities) you probably want FlowEngine
    • kingrichy
      • Jul 2024
      Gotcha - thanks for the quick reply!
