Welcome to the 3DF Zephyr tutorial series. This guide will present the tools for cleaning point clouds.
The tutorial targets all 3DF Zephyr Versions.
Manual editing is often used to remove noise in the generated point clouds. Although the confidence removal tool can clean the most noise out of the point cloud automatically, sometimes some manual editing is required for even better results.
Load any dataset you wish to experiment with and ensure you have generated at least the Sparse point cloud.
Select the “Editing tab (1)” to access the editing tools. In there, you can notice two different sections: the “Select” (2) section; and the “Edit” (3) section.
The “Select” section offers you tools useful for selecting points in many ways and then, when selected, editing them with a tool in the “Edit” (3) section.
Clicking on the “By hand” selection mode icon to open the manual “Selection” window, where you can find different manual selection tools:
– Rect icon: drags a rectangle on the workspace, and all the inside points will be selected (highlighted in red).
– Poly icon: click the points of a polygon (and close the polygon so that the last point as the same initial point). Similarly, all the selected points will be highlighted in red.
– Elliptic icon: draws a circle on the workspace.
– Lasso icon: allows for a free-hand selection.
– Box icon: select points inside a box.
Additionally, the Mode section offers three usage modes for helping the selection:
– Add mode can be used to add currently selected points to the selection.
– Remove mode can remove currently selected points from the selection.
– Pause/Resume mode can be used to pause – resume the selection mode and switch it to the overview mode.
The Edit section below allows to Delete, Copy, Invert, and Cut the selected points.
The following selection tools offer other methods to select points:
Some users may also want to use the “Confidence” tool to remove the points in which Zephyr has less confidence, which usually happens to be noise.
After the selection, you can also use the “Cut” and “Copy” tools (which do not work on the sparse point cloud) to split or make a copy of selected points. Or you can “Invert” the selection. The same Manual tools can be used to remove parts of meshes.
The next tutorial will show how to record a movie directly inside Zephyr. Proceed to the next tutorial.
