3DF Zephyr can deal with any 360° images by decomposing each picture into 6 pinhole like cameras using the utility "Decompose equirectangular panoramas". The images then will be treated normally.
The tool asks to select at least one picture as well as to specify a destination folder.
8 panoramas and the resultant pictures after the "Decompose equirectangular panoramas" tool has been exploited
You can select which side of the equirectangular cameras will be extracted by checking the appropriate side. Since v3.700, 3DF Zephyr will optimize the extracted sides and use them as constraints during the Structure from Motion phase as long as the filenames of the extracted cameras will keep the suffixes in the filename ( _left, _right, etc.): Zephyr will however ask for confirmation in the project wizard.
