Handle laser scanner point clouds
Since version 3.0, Zephyr supports laser scan native format files.
In order to install native laser scan support, you have to install the free plugin for the desired format from http://www.3dflow.net/native-laser-scanner-support-plugin-3df-zephyr-download/
3DF Zephyr Lite and Free can open (as viewer) laser scan format files as well, while the full version of 3DF Zephyr also have the option to import those file in the workspace.
3DF Zephyr supports the following native format files from the following laser scan device manufacturers:
- Faro (.fls, .flw)
- RIEGL (.rdbx)
- Dot Product (.dp)
- Z+F (.zfs)
- Recap (.rcp)
