Multispectral orthophoto composition
If more bands (layers) are available in the workspace, the following section will also be shown in the Step 2 - Resolution page of the orthophoto generation wizard.
You can select the desired bands in outoput and eventually create your own composition by clicking the "Add band" button and using the following interface:
You may also click the "Load transform" button to access previously saved data (e.g. NDVI) or use the save button to save your user defined formula.
